I already have a 10/100 ethernet at home with 3 pc's connected to it. I've just got another that I want to connect to the existing network, and would like to go wireless for this pc (and any future ones).
At the moment, the internet comes from a cabletv box, going into the main pc, and the connection is shared between the others. I don't really want to change the working network.
So, to connect the new pc to the existing network to share files, printers and the existing connection what kit do I need? I don't want to spend a lot of money on this, so only want to buy what I need to get this networked
Do I need an access point and a PCI wireless network card? Do I need a router? If I get a router, will it share all the files/printers as now as well as the internet connection?
What's the best way to go basically. Thanks for any help on this.
