Yes. It acts as both a transmitting and receiving antenna.
Is there some reason you didn't disclose the manufacturers and model numbers?
That's kinda difficult to answer because we have no clue what PDA you're using. Some have internal u-FL connectors but will require drilling a hole to extract the coax. The ones with CF card radios, have the radio externally available. If it has a projecting bulge for the antenna, it can be drilled and a coax pigtail connected. Are you sure you wanna do this?
