I have a laptop with a Linksys WPC11v4 wireless b card in it (hand-me- down for my daughter), but the card was bent and no longer works. When it was working, the link would drop or be very low connecting to my Netgear WGR614v1 (b/g) router. The house is plaster/lathe, and I've tried a reflector, but the intermitant connection was not alleviated.
My work laptop has an Intel card built in and works much better.
My question is ... should I expect better range performance with a new card or is there something that I should specifically look for when buying the new card?
I've read that N will probably not provide me with any better performance in my g setup.
I was thinking about getting another Netgear card, since my router is Netgear, but did not see the dB ratings in the specifications for the cards that I've looked at online so far. There were a couple of Linksys cards listed at 18dB.
TIA, Dave
