What does the asterisk (*) or the plus (+) mean beside the channel number?
TIA...
TIA...
"Blue Streak" hath wroth:
Q: What is the difference between SNR+ and SNR in Netstumbler? A: Anytime you see the + that means that is the best of that category you have gotten off that AP. In this instance the SNR+ would be the best Signal to Noise Ratio that you have gotten off that AP and the Signal+ and Noise+ would be the highest signal and lowest noise from that AP.
I think you can decode the rest.
