Starting situation: NETGEAR wireless signal broadcasted with out a password. Wireless connection worked well.
What I've done so far:
- I've changed my password to my default gateway.
- Changed my SSID & removed the check in the box that asks if i want to allow it to broadcast my SSID.
Haven't done:
- Created a WEP key
Current situation: Now about every 15 minutes or so I lose my connection consistently then receive the following message:
Wireless network connection
Windows could not connect to this network
There might be interference between this computer and the network access point, or the network is refusing access to this computer.
To restart the connection and try to establish full connectivity, click repair.
If clicking repair does not restore connectivity, the problem might be with the network, not this computer. Contact the person who manages your network.
Then, when I click repair it says that it was unable to connect to the network.
Anyone know what to do to remedy this problem?
