I am trying to set up a wireless network using 5 Netgear WG302 APs on a flat corporate network with DHCP.
Having set them up as per the documentation I can get nothing to work. Non of the clients can be reached from the master.
I have one set as a master in Point to Multi Point Bridge mode with the MAC addresses of the other AP's and connected to the network via an Ethernet cable.
I have the others set up in Point to Point Bridge mode with the IP address of the master as the remote MAC address.
The only way I can get more than just the master working is to change one of the clients to Point to Multi Point Bridge. That way I can ping both the master and client and I get an IP address when connecting via the client.
Has anyone come across a similar issue before or has anyone successfully configured these?
Thanks!
