I've been trying to get this new adapter working under the above referenced config. Today I used Control Panel/Remove Programs and removed the Netgear configuration program(s) completely.
Upon completion I then plugged in the USB adapter and the usual dialog popped up asking for a supplied CDROM. I inserted the Netgear supplied one and selected the XP drivers. The install went smoothly and as expected.
Now, when I scan for networks it displays my WPA secured network (along with several others) and when I double click it it goes through the connection actions culminating with Obtaining Network Address and finally Connected (Hurray).
But EXACTLY four seconds later the connection is dropped and the process starts all over again and again and again and again.
I am at my wits end with this. Has anyone experienced this action before and if so what, if anything, was done to resolve it?
Any suggestions, advice, pointers will be greatly appreciated.
Thanks,
Bob
