My SMC7004WFW doesn't seem to like Windows XP. Either that, or it's just flaking out after two years. The Orinoco and DWL-122 both connect fine to other WAPs. They connected fine to the SMC when they were running Win2000, but running WinXP they flake out every couple of hours. I have to reset the SMC to get internet access again, although the connection still shows solid.
Both wireless are useless once the SMC locks up. Wired continues to be fine.
So, wandering through Fry's Electronics on Thursday, I bought a Netgear MR814v2 for $22.00. I figured I was having more than $22 worth of frustration with the current setup.
But the antenna on the MR814v2 is fixed instead of removable, so I can't use my external Connifer antenna. I wouldn't be able to use my RP-SMA cable anyway, so I would have needed a new cable even if the Netgear were detachable. I'm thinking of hacking the Netgear open and wiring in a short length of cable and an N-connector to go directly to the Connifer.
In the meantime, I thought I'd drop back to a reflector on the existing MR814v2 rubber duckie. But wait... I get excellent signal at the far end of the house. That was never true on the SMC, which is how I got interested in reflectors and USB-cantennas in the first place.
Is the WR814v2 a wonderful new toy? Why is it only $22? 802.11b that far out of favor? It's faster than my cable modem anyway.
