Netgear MA311 task tray utility trouble
I recently bought a Netgear MA311 wireless router/modem and PCI adapter card. I downloaded the most recent driver for it from the netgear support site and installed in on a Amd Athlon T-Bird based PC running XPpro.
Weird thing is, the connection works, I am actually using it to access the internet right now, but the Adapter configuration utility in the task tray appears 'red crossed'. Can't access it by clicking the task tray icon, the shortcut in the programs bar, or the program itself in the Program files dir.
XP hardware manager shows hardware is installed and works properly (well it does actually, but I can't configure anything).
Anyone knows this problem, and even better, has an idea how to resolve it?
Thanks in advance
Ben
Ben
access
resolve
Do you have the "Use Windows to configure my wireless network setting? checked in the connection properties?
Airhead
