I would appreciate any help on the following, I'm using a Netgear DT, Wireless, ADSL Router - DG834GT, (the router is connected to a PC using Windows XP) the issue is that I'm now starting to have problems on a daily basis with it.
Regularly I have to unplug the power, and then reconnect it, then the router connects and works again, I never had to do this before, however this is now starting to be a regular occurrence.
One thing is that I have recently update the Firmware and used Version
1.02.04, I wonder to whether this could be the problem, and if so how can I uninstall the router and recently installed firmware and start again (as system restore does not seem to fix this problem).The strange thing about this is that when the router works, a Windows XP laptop, which uses this wireless connection, has less dropouts as the signal seems stronger.
Any help on the above would be gratefully received.
