I'm tearing my hair out trying to get my network to run in 108mbps mode.
I have:
Netgear DG834GT 108mbps router
1 PC with Netgear WG111T 108mbps USB adaptor 1 PC with Netgear WG311T 108mbps PCI adaptorAll the above work fine together in b/g modes. But they just won't work in
108mbps mode. They only way I can get them to work is be disabling WEP and even then they commincate with each at super low speeds. Opening a 10KB text files takes 10 seconds.I have the router set to "108mbps only", it runs on channel 6. Both adaptor have been set to use 108mbps mode only, but I'm having no luck. All 3 components are less than 12 feet apart too!
Settings the router to "auto108mbps" improves speeds, BUT it will only work if I set both adaptor use normal "g" 54mbps, which kinda proves that none of the equipment is running in superG/T mode. Anyone any ideas?
