I want to attach an better antenna to my Netgear WGR614 (802.11g router), but it doesn't appear that the antenna is removal friendly...............any ideas on how to elegantly and simply remove? Thanks.
- posted
19 years ago
Solder Iron? Most non-removable antennas have soldered connections, you can remove them and solder on a connector, but, next time you buy make that one of your requirements........
