Hi, I've got a problem with a few clients running WinXP SP2.
When configuring a secure wireless connection with the Windows Zero Configuration, the network authentication options that I can choose from are only Open or Shared (Whereas in WinXP SP2 I should be able to choose WPA too).
I've tried to install the Q815485 patch (WPA support -
The NIC's drivers are updated, but I must use WZC and not the vendors utility to configure the WLAN.
Does someone knows how to solve this issue?
Thanks, Oren.
