I have a Orinoco AP2000 that has worked great for years with a range extender antenna, now, I just bought a much larger house and the kids upstairs cannot get a good signal.
I recently bought two Linksys WAP11's to see if 1) will they act as repeaters for the AP2000, no luck there. And 2) can I use one WAP11 as an Access Point and the other as a Access Point Client(repeater). I havent really had any luck there either. with that setup, what should I be able to see from my laptop? the AP client SSID? or the AP SSID only with a stronger signal? I havent had any luck.
If It is not reccomended that I get these WAP11's working, what is a better solution? I am willing to replace all the equipment or buy something that works with my AP2000(preferred).
If you fancy trying something different, you could try HomePlug - ethernet over the mains power circuit.
People seem to recommend Devolo MicroLink dLAN stuff. However, I remember reading a couple of reports about them being easily killed by power surges. If your power is stable, that might not be a concern.
How many walls and floors between the AP2000 and the kids? How far away? What's the general wall and floor construction? What manner of radio are the kids using? Any add-on antennas?
Is this "range extender kit" an omnidirectional antenna? If so, have you tried running the antenna horizontally to get better signal in the up/down direction? If this works, perhaps a panel antenna pointed upwards would work. It really depends on the house layout.
Give up. The problem with repeaters is that the standards for such operation in IEEE-802.11-1999 are seriously deficient and vague. The result has been a variety of incompatible hardware implementations. The WAP11 is probably the worst of the bunch. I have a few of these that I've inherited from various upgrades. None work right as a repeater.
What versions WAP11's? V1, v2.2, v2.6, or v2.8. They're all different. Look on the serial number tag for the hardware mutation.
Forget the repeater, although I must admit that it will probably work. The WAP11 in repeater mode is probably compatible with another WAP11. However, I would make sure they are the same hardware mutation and firmware version.
I've had good luck using the WAP11 as an access point client. It does have some weirdness. It sorta goes to sleep when not used, and disappears from the network. However, when I wake it up, it takes a while to respond and results in some rather odd looking pings. For example: Pinging 192.168.1.50 with 32 bytes of data: Request timed out. Reply from 192.168.1.50: bytes=32 time=46ms TTL=127 Reply from 192.168.1.50: bytes=32 time=1ms TTL=127 Reply from 192.168.1.50: bytes=32 time=2ms TTL=127 Oops, that's a DWL-900AP+, which is the same as a WAP11 v2.6. Close enough as I get the same problem with the WAP11. Most of the TI ACX100 chipset routers are fundamentally the same inside:
Well, for a repeater to work, it has to have the same SSID as the rest of the network, and be on the same RF channel. When you connect to the IP address of the AP2000, you'll get the router. When you connect to the IP address of the WAP11 repeater, you should get the WAP11 config menu (unless you have v1 or v2.2 which were mostly USB configurable). When you scan for available network, you'll see just the one SSID. However, if you have more advanced tools that show devices by both SSID and MAC address, you'll see both the repeater and the AP2000 listed, with the same SSID, but different MAC addresses.
Forget the repeater idea. The AP2000 is kinda old and 802.11b only. If this is sufficient, then methinks playing with antennas or a 2nd AP upstairs might be a solution. Otherwise, get an 802.11g wireless router.
Here's what I suggest (in the following order):
Play with antennas and see if you can improve the signal strength. Point directional antennas upwards. If the walls and floors are concrete, steel, or masonry, forget it.
Add an access point upstairs. It doesn't have to be labeled an "access point" as any wireless router can be used as an access point by simply disabling the router section and disabling the DHCP server. How this added access point communicates with the rest of the network is a problem. CAT5 cable would be best. Power line networking can also work:
There is also phone line networking and piggybacking on the CATV coax. Details on request (or use Google groups search).
Replace the AP2000 with something 802.11g and better. Hopefully, it will have better range.
Power line networking and forget about wireless if the house is impervious to RF at 2.4GHz.
