OK, I need some help. I've been trying to find my WEP key and I still haven't had any luck. So here is my situation: I go to 192.168.1.1 and enter the username and password. It takes me to some page with ZYXEL up in the corner. The WEP key is nowhere to be found on this page. On a windows XP, I also tried doing start>control panel>network and internet settings>wireless network setup wizard. Then I hit next>set up manually>print network settings. That brings up a text document that says "Network Key (WEP/ WPA Key): blah blah blah." I tried using that 26 character key but it wouldn't work. I need the WEP key for a laptop and an Xbox 360. I already have it working on another laptop, a PSP, and a Wii. Sadly, I can't remember how I got them to work. My question is what am I doing wrong/what else can I try/how can I disable a WEP encryption (or whatever it is).
I would greatly appreciate your help and advice!
Thanks
