Hey everyone - I have 2 privates subnets : one (192.168.0.0) for my wire network and Internet, and the other (192.168.1.0) for the wireless. I want to setup a wireless network with a linksys WRT54GS router and have access to Internet.
SHEMA
(X)-------------------------(X)___________________________(()) Router A (wireless) Router B (wire) Internet
192.168.1.0 192.168.0.0I already set the configuration on the router and the communication is established with the wireless network. My problem is when I'm trying to browse.
From the administrative tool of the WRT54GS I can easily ping or traceroute, for example
I get this error when I'm trying to ping
2) It's not better doing this: Ping 64.233.161.104 : request time out
3) 192.168.0.9 (DNS) doesn't work eitherHowever when I type Ipconfig /all into the console, it gives me this stuff and find also the DNS
IP Address. . . . . . . . . . . . : 192.168.1.100 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.22 DHCP Server . . . . . . . . . . . : 192.168.1.22 DNS Servers . . . . . . . . . . . : 192.168.0.9 203.108.60.11 203.108.60.12
I'm aware that my wireless and wire networks are in 2 differents range of IP and it's probably the reason why I can't get internet with the wireless device.
Remember that all works fine on the router. I am able to ping or traceroute google or my DNS. It's only with windows and my browse that I can't access Internet.
Any help would be greatly appreciated, I really need a solution
Finally here is my router config, if it could help
--------------------WRT54GS Status--------------------------
------------------------------------------------------------ Internet: Login Type: Static IP Address: 192.168.0.22 Subnet Mask: 255.255.255.0 Default Gateway: 192.168.0.10 DNS 1: 192.168.0.9 DNS 2: 203.108.60.11 DNS 3: 203.108.60.12 MTU: 1500
Local Network: MAC Address: 00:0F:66:D8:51:37 IP Address: 192.168.1.22 Subnet Mask: 255.255.255.0 DHCP Server: Enabled Start IP Address: 192.168.1.100 End IP Address: 192.168.1.129
--------------------End Router Status-----------------------
