Hi I bought an 12 dBi TurboTenna Antenna.
I have a pcmcia card 2835 SMC I opened it conected a rp-sma connector to the card.
I also made a cable for my antenna one side with rp-sma male and the other with a Nconnector on it.
I connected all together and I pointed it at my AP and I don't have a better signal on it .
How can I teste this to make sure that it is not the card or the cable that has the problem??
I'm new in this thing of wifi.
thanks any ideas is apreciated
