Ok. Here's what I got going....
A DSL Modem in my daughters room where the MAIN LINE COMES IN AT, feeding into a D-Link WIRED ROUTER.
The wired router then feeds into three other places and the fourth feeds into the living room where the DI-514 WIRELESS is at. I got three ports going to other stuff, but I want to set up the wireless for my PC right across from it about 5 feet away.
I tried to set it up, and get an excellent signal strength, I can get it to connect, but I can't get it to go online when clicking explorer! So I went into my daughters room and did the start, run, cmd, ipconfig/all thing and found that the D-Link IP address in her room is IDENTICAL to the D-LINK address in the living room (which I believe is the problem as two devices can't use the same Ip address).
So here goes my question....
How can I change he DI-514's IP ADDRESS to something totally different so it will connect to the internet (if indeed that is the problem at all)?
If it's not the problem, are there any other ideas as to what the problem could be?
Thanks for all the help in advance, as my daughters room works perfect so I know I'm already more than halfway to the solution....
Charles
shifty snipped-for-privacy@hotmail.com
