A while back there was a discussion of how Windows chooses which network connection to use when there is both a wired and wireless connection:
Does that same discussion apply to multiple wireless connections? I.e., if my laptop's internal WiFi adapter and my USB-connected WiFi adapter are both connected to the same NAP, is the "least expensive" connection still used?
Does each connection automatically get a different Metric value?
Can those values be manually assigned?
Is there any down side to having both connections active?
Yes. The major issue is that each "interface" (that's an ethernet port, wireless card, or other network connection) must have a unique MAC address associated with it. You can't have the same IP address assigned to multiple MAC addresses. Therefore, you can't have multiple connections with the same source IP address. If you simultaneously run multiple ethernet or wireless cards, the output of:
Anyway, if I try to assign the same IP address to any two of these interfaces, Windoze will complain. This may not seem relevent, but please read on.
Yes. The problem is the same as previously mentioned. Each interface on your laptop has to be unique. Different MAC and by implication, different IP. However, your IP route to the router will be different for each wireless card. You can connect, associate, login, and connect, but the traffic will only move through one of the wireless connections. Unless you're running some load balancing router software, that distributes the traffic from multiple IP's to a single destination IP (i.e. your router's IP address), it's going to be very unbalanced traffic. Worse, you can't switch destinations on the fly, because that will initiate a disconnect.
All is not lost. You can connect two seperate wireless cards to two seperate access points (each with a unique IP address) and simultaneously move traffic to both. That's done with a static route to one of the routers and the network behind it. The other route is the default route, which takes care of everything else.
You might want to read the research articles under:
It's not directly related to what you're doing, but the last two articles do expand on my previous ranting.
I dunno. The above example with 3 connections yielded a metric of 1 for all connections. There's actually a 3rd ethernet card installed that I forgot to enable. When I turned it on, it didn't get a DHCP assigned IP address and received a metric of 30. However, in all other respects, the other 3 interfaces have equal route "costs". Incidentally, this is on Windoze 2000 SP3. I'm too lazy to get my XP laptop out of the truck and see what it does. I suspect it's different, as Vista might be because I vaguely recall that there were some changes in various service packs.
Yes.
Configuring Multiple Adapters on the Same Physical Network
The bottom of the page shows how to manually tweak the route metric.
An explanation of the Automatic Metric feature for Internet Protocol routes
Self interference. Even if the two wireless adapters are on different 2.4GHz channels (which is impossible when connecting to a single access point), you're gong to have mutual interference. You might get away with connecting to two different access points, on different channels, or preferably, different bands.
Also, stuffing in a 2nd interface to the same destination does NOT double your thruput. You get whatever speed is supplied by the single wireless interface, with the other wireless interface doing nothing.
If you have any questions, BEFORE you ask, please supply:
