Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by P.Schuman on April 13, 2008, 12:36 pm
Please log in for more thread options For some reason, they had acquired a couple of Linksys b/g WAPs and had "stacked" them on top of each other..... they fit so nice :) So the antennas were almost touching each other. I was wondering, if you were going to run 2 WAPs in very close proximity, how "should" you physically arrange them ? My RF knowledgebase only has mental entries for 2m & 450 repeaters. -- ---------------------------------- "If everything seems to be going well, you have obviously overlooked something." - Steven Wright | ||||||||||||||||
Posted by Jeff Liebermann on April 13, 2008, 3:04 pm
Please log in for more thread options Bad idea. 802.11g and all spread spectrum transmissions do not stay within a nice neat spectral mask. In theory, spread spectrum transmissions spray RF well outside the official occupied bandwidth. For example, if you have an access point running on Ch 6, you'll have the bulk of the RF energy between Ch 4 thru Ch 8, but here will still be some RF all the way out to Ch 1 and Ch 11. The amounts involved are not huge, but at the very close proximity of the boxes (and presumably the antennas), self-interference between radios is going to be a problem. Even if the system uses a mess of external antennas and coax cables, there will be case leakage problems. The WAP54G and WRT54G boxes (the only ones that stack neatly) are not internally shielded. They will radiate through the case to each other quite nicely. The band pass filter at the antenna is useless because it only prevents out of band radiation. It merrily passes everything that's in band. The effects of such interference is not huge. It mostly shows up as a high packet loss or a loss in thruput. Having the connection speed slow down is also an indication of problems. The easiest test is to use ping: Start -> run -> cmd <enter>
ping -t ip_address_of_access_point
You should see a *consistent* 2-3msec latency. If it varies all over the place, and/or shows timeouts, you've got a problem. However, that's for just one access point. Generate some traffic to one of the other access points, and see how it affects the ping results. If they were fine with just the initial setup, but where adding traffic on the 2nd access point cause the latency to climb, then congratulations, you have self-interference. >My RF knowledgebase only has mental entries for 2m & 450 repeaters.
I spent yesterday getting IRLP running to our club repeaters. Some bright person (me) suggest that this would be a great time to move racks around. My back and wallet both hurt. Tomorrow we do EchoIRLP. <http://www.LearnByDestroying.com/k6bj/IRLP/>
-- Jeff Liebermann jeffl@cruzio.com 150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 http://802.11junk.com Skype: JeffLiebermann AE6KS 831-336-2558 | ||||||||||||||||
| Similar Threads | Posted |
| multiple WAPs - physical proximity | April 13, 2008, 12:36 pm |
| NEWS: Sony Develops New Close Proximity Wireless Transfer Technology "TransferJet" | January 14, 2008, 10:10 pm |
| physical location of AP | November 18, 2004, 3:38 pm |
| wrt54g wds and physical network ports | April 8, 2005, 12:37 pm |
| How to find out client physical location? | January 6, 2008, 4:37 am |
| Is having too many WAPs in one area a bad thing? | April 10, 2005, 7:29 pm |
| Two WAPs connected by cable for roaming? | September 9, 2007, 12:34 pm |
| Multiple APs | May 9, 2006, 9:12 am |
| Multiple AP | November 9, 2007, 5:33 am |
| WDS using a multiple WAP54G | November 20, 2004, 2:52 pm |
| connecting to multiple hotspots | January 12, 2005, 10:00 pm |
| Multiple Wireless APs in Warehouse. B vs. G. | November 30, 2005, 11:08 am |
| How to combine multiple networks into one? | February 21, 2006, 6:47 pm |
| multiple radios one antenna | February 27, 2006, 1:43 am |
| Using multiple access points | March 13, 2006, 6:15 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
