I just picked up a Motorola WPS870g print server to use on my Motoroal wireless network. There is a point in the setup where you disconnect the ethernet cable from the print server and the print server is supposed to find the network. Not happening.
I've got my printer plugged into the PS parallel port, all other motorola components on my system (to help ensure compatibility), and a WPA-PSK/Tkip securing on the network that operates on channel 7.
Motorola tech support told me that I MUST HAVE file and print sharing ENabled on my XPproSP2 box but couldn't tell me how to do that (and mine wasn't enabled). I've since discovered (I *think*) how to do that but it hasn't made any change in the motorola setup process.
Any help or ideas are greatly appreciated.
thanks, John
