Mk 2 USB WiFi antenna !
Half the WiFi world seems to have latched on to the Poormans USB WiFi "scoop" antenna idea we rustled up mid 2004, with ~1000 hits daily still averaged at the resource page =>
To suit situations where such Chinese cookware WiFi antenna may be
-ah- "visually distracting", we've rustled up a more professional USB WiFi parabolic design based around cheap cooking sieves and a flexible stalk desklamp base. See pix & Netstumbler testing graphs =>
Performance, measured with NS,indicates 12+ dB gain over a bare USB dongle- the classic " scoop" gives more like 15dB of course. When spray painted black, the Mk.2 setup looks almost invisible & could easily be used in a library etc with ones laptop - cover with a plastic bag or jersey perhaps for discretion. Bill of materials ~NZ$15, with parts readily available via "The Warehouse" etc.
Recommended ! Stan in NZ
manuka
What is the diameter of the Sieve in the picture? You'd think it would be an easy item to attain, but most are only 8-9inches (20.32 cm - 22.6 cm) with
10inches (25.4 cm) being conisdered the LARGE ONE by most suppliers. I have found some 12-14 inch ( 30.48 cm- 35.56cm )models but they aren't quite shaped right, and they are going for around $30 plus shipping USD. Worth it if you could know it would work and gain properly, but a lot to just cut up and find the wrong design and dimensions. Great idea and thanks. When I find the right supplier I will post. (USES Wise that is ) Also, some have a coarser mesh. Is small mesh preferred?
helpster
