The access point and nic worked for several months and then it stopped. I thought that I had a problem with thw WG111 NIC, so I updated the driver...no luck. Then I searched the net, netgear, and groups without finding an answer. I finally checked the netgear page for the access point and found that there was new firmware...30.21. Don't count on flashing the firmware remotely...I had to climb the ladder and get the AP in my hand. The firmware solved the problem.
Now if I can just figure what the problem is with the JetDirect EW2400 print server.
