Im building a wifi Tower which i'm using to supply a whole community with wireless internet, i bought a 15dbi omni directional antenna and a
24dbi directional antenna.I am thinking of putting the tower about 8ft above the height of the houses which is 9 1/2 ft high. Note the Community is Really big and im on a little hill which is the highest point of the community..I need some help to construct this Successfully, i will be here to give all the info you need to help me out..
Please note that i want to use a pci wireless card on all of the client machines without them have to use a outdoor antenna..
My Wirelss Ap is a US Robotics 1908.
_Technical_Specification_of_the_15_dbi_omni_antenna...__ Frequency Range 2400 to 2500 MHz Gain 15 dBi Impedance 50 ohms Polarisation Linear Vertical Connector RP SMA Male or N-Type Female Dimensions Height 1860mm Depth 40mm
_SUMMARY_of_24dbi_Directional_antenna...._
2.4 GHz ISM Band Wireless Bridges Backhaul Applications IEEE 802.11b and 802.11g Wireless LAN WiFi Systems Point to Point Systems Point to Multi-point Systems Long-range Directional Applications 8° beam-width 24 inch coax leadPlease For all your help..Thanks:D
