MAC address
No. You can get the manufacturer of the wireless card from the MAC address. If you're clever, you can measure (ping) the range to the wireless card and use that to estimate a location. If you're an aspiring terrorist, you can build a HARM (RF seeking) missile that will home in on a signal as identified by the MAC address of the access point. What are you plotting to do?
Jeff Liebermann
Can I get the physical location of the access point from the MAC
address of the AP?
jiten
jiten dash
How could you possibly do that? The mac address is a numeric ID in a chip on the adapter....
However you could triangulate for the location, using a directional antenna and a laptop.
Mark McIntyre
No, you can't get the position of a person from it's passport number either...
Thomas
Thomas Krüger
Now *that's* wardriving.
Neill Massello
