I'm confused!
This card and network works fine under Win98.
I installed WinXP [which I run on my desktop]
Now the card is enabled but won't connect.
I've enable/disabled/started/restarted Windows Wireless Zero service.
I can get WinXP to see the network and it try to connect but, oddly, after it goes through connecting, the XP configuration manager then shows "disconnect" as an option at the bottom of the screen but "not connected" at the top where "automatic" had been before.
I'd just as soon not use the WinXP manager anyway. But in that case, the card is working but I can't get WinXP to find the network.
Comments on where my thinking is defective appreciated.
Thank you.
