I encounter small problem with my WRT54GL router with Tomato firmware
1.21. Router is connected to Internet via Cable modem. I have 3 devices connected to this router - all of them via wireless connection. On one laptop (Windows XP Professional) I have FTP server (guildftp) plus emule and I think that's all. On other laptop there is Windows Vista Basic and I?m using this for simple internet - www, IM. And third device is Iphone, which is connected all the time, but data transmission is used only occasionally. No firewalls installed and active on any of the laptops. On one I have local, polish, arcabit antivirus software, on second home version of Avast. Nothing else. I?m having this configuration for some time, but I remember when I had other PC with Windows XP and Windows Vista Basic ? it was exactly the same ( I had them only for a while, so I didn?t think about that at all) And the problem i have is with transfer data between laptops ? I?m trying to download anything from laptop with Windows XP, through FTP using Total Commander I get transfer at 5 KB/s ? and it takes ages to download anything. Pinging each computer causes about 1/3 of pings not to be returned. PCs are close to router, from both of his sides. Connection to Internet works perfectly fine ? on both laptops I get full Cable modem speed, downloading and WWW works fantastic. Only transferring data between PC?s is awfully slow. How I can diagnose what is a problem? What i can do to transfer data not using usb flash drive?Thanks
Piotrek
