Hi guys, I have laptop, I use an Alfa AWUS036H wifi adapter on my boat. After having some difficulty connecting on my boat, I installed new (RTL8187)? software. I didn't uninstall the first install, but it did connect (usually). I had two different icon signal indicators in my tray. So, I uninstalled (what I think is the old RTL8187 software. The uninstall did not remove the second signal icon from my tray, however now I can't find my original OEM wifi unit. I can't get online while at home. Before uninstalling the program I saved it!
I thought maybe the program I uninstalled was the driver for the built in Toshiba wifi adapter. But when open the folder the files also seem to be related to the RTL8187. But, I don't know what the Toshiba uses, so it could be the original Alfa software or maybe for the Toshiba wifi adapter. As you see I'm a bit lost.
Here is a list of what's in the folder I uninstalled. net89xp net8187b net8187Se net9192ce net9192se Is this anything to do with my OEM Toshiba wifi drivers?
OR,
How do I get the OEM wifi on my laptop to work?
Thanks for any help. Mikek
