I have recently switched from using WEP to WPA-PSK. When switching users or when restarting the machines my network connection "loses" the password. Once I re enter it the connection is re-establiched fine. How can I stop this?
What are you using to manage the connection? If Wireless Zero Configuration (part of Windows XP), then the passphrase should be saved automatically. If something else, then you may need to explicitly enable saving of the passphrase. In the case of Windows XP WZC:
Have you made sure the connection is configured for _auto_ connection (not manual)?
Does Repair the connection work? It can take up a minute to reestablish a connection.
For more info, see:
Wikis below
"How to troubleshoot wireless network connections in Windows XP" .
I am guessing that you mean on the Association tab of my wirelss network properties the "key is provided for me automatically. If so then this is greyed out and cannot be changed. If not then where do I locatethis option?
