Long range wireless
Threaded View
Hello,
I'm trying to transmit telemetry from a race car to a base station via
802.11. It's mostly wide open terrain, but the range need is ~0.5
miles, even 1 mile at some tracks. Is it possible to achieve this via
802.11? I've seen 27dBm transmitters (http://www.quickertek.com /
Quicky.php), 12-15 dB omnidirectional antennas, but very scant info
regarding the actual range achieved (because of variable conditions,
etc). I can put a laptop (or even PC) in the race car, and put an omni
antenna if need be at both locations... but would it be enough?
Thanks!
Alex
Re: Long range wireless
Barely, just barely.  Some of the local drivers have tried Wi-Fi for
telemetry with mixed results.  You can't install a directional antenna
on the vehicle and it's a pain to install a tracking dish antenna on
the other end.  However, the real problem is that many tracks have
hills, buildings, and stands in the way, thus ruining the line of
sight.  That means multiple access points.  There are also technical
problems involving time it takes to switch access points, and doppler
shift.  All are solvable, but kinda a mess.
A 15dBi antenna has a -3dB beamwidth of perahaps 5 degrees or less.
(It's 3am and I'm not going to look up the actual value).  Even the
slightest tilt of the antenna will cause signal loss.
I'll expound later on my personal experiences with laptops in
automobiles.  Let's just say that nothing less than a Panasonic
Toughbook on shock mounts is going to survive for long.  PCIe solid
state hard disk if you can afford it.  See:
<http://www.mp3car.com/galleries.php
for photos of how some do-it-thyself vehicular computer installations
were performed.
What you managed to leave out is what type and speed of data are you
planning to send?  Speed and range are inversely releated.  If you
don't need all the speed of Wi-Fi, you can get quite a bit of range
from other technologies.  See the serial port versions of these
companies products.  Look at 900Mhz, not 2.4GHz.  You won't get much
thruput (perhaps 50Kbits/sec) but you won't need ultra high gain
antennas and your range.
http://www.freewave.com
http://www.maxstream.net
http://www.avalanwireless.com
http://www.data-linc.com/wireless.htm
http://www.moxa.com/Zones/Wireless_Ethernet /
(etc...)  Search Google for "wireless serial", "wireless rs-233", and
"wireless ethernet".  Mostly they're industrial products, with low
thruput, and fairly high prices compared to cheap wi-fi.
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
Site Timeline
