I would like to link two properties up wirelessly that are 745m apart, and can (just!) see each other.
The link will be used for internet access, VoIP and general data transfers, all over TCP/IP.
Just wondered if anyone here has done something similar, and could point be in the direction of suitable external antennas?
Would two yagi type antennas be the way to go (I need to mount them both externally, on the chimney's)
Thanks!
Toby...
