Lock PC to channel 6
Threaded View
Hi
I have a PC running XP and Realtak 8180 WIFI card.
How do I lock it to channel 6?
Problem is that there are so many WIFI in my area, that I cant connect
unless I can lock it to channel 6 - it weavers all the time to
stronger signals on channel 11.
Weird.
/// JJ
Re: Lock PC to channel 6
Do you have a wireless router or an Access Point that you use your
realtek card to associate with?  If so, there might be a feature in
your router's menu that will allow you to enable or disable
autoscanning of less used channels.  I am unfamiliar with your Realtek
card.  If it is a super-g card (108mbps), then it will more than likely
default to channel 6 if super-g is enabled.  Still, that will depend on
the settings of your wireless router / AP.
doug Jamal
brought to you by http://www.wifi-forum.com /
Site Timeline
