I have a router that I think will do load sharing between two internet connections. It's an ASUS RT-AC66U. The internet connections are:
1: Local WISP: Radio on roof feeds through a Cat 5 ethernet cable to the router's WAN connection. Speeds are slow, 3Mbps max. The WISP is pretty reliable, if slow.- Hughesnet Gen 5: Dish on roof feeds through another cat 5 cable to port 1 on the ASUS.Speed are usually good, up to 25 Mbps The satellite service is less reliable, heavy rain (I'm in Houston area) causes loss of signal.
The ASUS software recognizes that there is a connection to a WAN on each port.
The software gives me the option of setting up as either failover or load sharing. I'd prefer Load Sharing, because one or the other sometimes gets very slow.
There's another complication.... the Hughesnet service is through their router. The system "works" with a cat 5 from one of the Hughesnet router LAN ports to the ASUS LAN port 1.... but both routers are DHCP servers. So far I've seen no problems with this.... but I haven't run both connected this way for very long.
AM I likely to have problems due to both apparently assigning DHCP addresses? I could turn off DHCP serving on the ASUS, but then I think the WISP wouldn't be able to serve any computers. I don't see any way to turn off DHCP on the Hughesnet router.
Is one or the other mode (Failover or Load sharing) likely to be more trouble free? Any advantage to either one?
My local network consists of three computers, a connection to a Dish network recorder, a connection to a Roku, and occasional access by a couple of tablets and cell phones. Ideally, I'd like to keep everything on one LAN, but if this setup with the one router is likely to have problems, is it possible to have two LANs, with some sort of connections so that the computers in one LAN and communicate with those in the other?
