Linux software to randomize PC hostname & wireless MAC for privacy at hotspots
Threaded View
If I understand Jeff L. correctly, hotspots often log your hostname and
wirelss car MAC address; so I wish to automatically change my wireless
card MAC and laptop PC hostname upon every reboot.
On Windows, I can change these things manually but there are plenty of
freeware packages which pseudo-randomize the hostname (based on a lookup
table) and wireless MAC address for added privacy at hotspots upon every
reboot. These work great!
However, on Linux, while I can change these things manually, I have not
yet found software that does so automatically upon every reboot.
Here's how I change the hostname on Linux manually:
$ sudo vi /etc/hosts
Change the contents of /etc/hosts from:
127.0.1.1      ubuntu      ubuntu
Change the contents of /etc/hosts to:
# 127.0.1.1 ubuntu ubuntu
127.0.0.1 foo foo
$ sudo echo foo > /etc/hostname
$ sudo reboot
And, here's how I change the MAC address on Linux manually:
$ ifconfig -a | grep HWaddr
$ sudo ifconfig wlan0 down hw ether DE:AD:BE:EF:CA:FE
$ sudo ifconfig wlan0 up
The question is where can I find software that will perform that task of
changing the wireless card MAC address and PC hostname upon every reboot?
Re: Linux software to randomize PC hostname & wireless MAC for privacy at hotspots
On Fri, 24 Sep 2010 16:59:30 +0000 (UTC), Y Knot wrote:
For about 99.99% of the time, whatever you can do manually, you can
put the commands in a script to do the same thing.
If you look in /etc/init.d you will see several scripts which execute
during system startup/shutdown.
If you look in /etc you will see several directories which contain
links back to /etc/init.d scripts.  Do a
ls /etc/rc?.d
Now look in a directory, with
ls -l /etc/rc2.d/*
Those S* links are the order they
execute during Startup and the K* are the links executed in that order
during kill/shutdown.
If you were to do the command
runlevel
you would see what level you are running and can look in that
directory to see what executes when.
If you do a
$ runlevel
N 2
the your runlevel is 2. So, do a
ls -l /etc/rc2.d/*
I your case you might try creating a /etc/init.d/rnd_hostname
then create a /etc/rc2.d/S05rnd_hostname link pointing to
/etc/init.d/rnd_hostname.
Next boot, S05rnd_hostname would run your script to change host name.
Going to guess you are running ubuntu. It runs dhclient which gets
your ip address and whatnot to connect to the internet.
Doing a      man dhclient  eventually suggests doing a
      man dhclient_script
which can lead to the fact that you can create a
/etc/dhcp3/dhclient-exit-hooks script. That is where I would try to
put code to munge your MAC address.
You might want to bookmark this url
    http://tldp.org/LDP/abs/html/index.html
You could create /etc/dhcp3/dhclient-exit-hooks with
echo $@ > /tmp/hooks
env >> /tmp/hooks
Set execute permission with
chmod +x /etc/dhcp3/dhclient-exit-hooks
After booting, look at /tmp/hooks to see what information is available
for your code.
Now, delete /tmp/hooks and restart the network and see what you have.
rm /tmp/hooks
service network-manager restart
cat /tmp/hooks
All the above needs to done from a root terminal. To get to a root terminal:
sudo -i
when through with root terminal, enter the command   exit  or do a control d
The warranty and liability expired as you read this message.
If the above breaks your system, it's yours and you keep both pieces.
Practice safe computing. Backup the file before you change it.
Do a,  man command_here or cat command_here, before using it.
No - this is too late: by then you've posted your MAC and received a
DHCP response. If you're going to tweak your MAC it should be done no
later than by a file in /etc/network/if-pre-up.d/ or a pre-up stanza
in /etc/network/interfaces.
Re setting the hostname, on my (Debian) box it's handled as part
of /etc/init.d/hostname.sh, which is called on system bootup as
/etc/rcS.d/S02hostname.sh. Obviously this may be different for Ubuntu
(I found the relevant script by running this command: grep -l hostname
/etc/init.d/* )
Chris
Yep, ubuntu hostname was not called in /etc/rcS.d/ or /etc/rc2.d/
I hear where you are coming from about dhclient-exit-hooks but you
have to decide if you want mac/hostname changed on startup, shutdown,
or each network restart.
I suggest setting them during shutdown. Major reason would be so next
boot would be pretty clean. You do not want to change host name after
some service/daemon has started with old name. Examples;  postfix,
sendmail, leafnode, dovecot,..
@speranza.aioe.org:
that task of
every reboot?
What makes you ASSume that they cannot id you by means other
than MAC and hostname? They can.
    http://www.alobbs.com/macchanger /
    Been around for ages. Packages available for ubuntu, debian,
etc etc
    Put it in rc.local. But why on boot ?
    Just link to a script. Don't forget the gksu, or whatever, you
need to be root.
    []'s
I already tested MacChanger which didn't add ANY value whatsoever.
It's EXACTLY the same number of steps with MacChanger than without
MacChanger (so what's the point of the program anyway?).
With MacChanger, the steps are:
1. sudo macchanger -s wlan0
2. sudo /etc/init.d/networking stop
3. sudo macchanger --another wlan0
4. sudo /etc/init.d/networking start
Without MacChanger, the steps are:
1. sudo /etc/init.d/networking stop
2. sudo ifconfig wlan0 down hw ether DE:AD:BE:EF:CA:FE
3. sudo ifconfig wlan0 up
The hostname can ONLY be changed (AFAIK) upon reboot anyway, so you may
as well do the MAC at the same time.
This is such a basic need that I'm sure a LOT of people have done it
already. The trick is to find them! :)
I'm working on adapting this script:
http://cryptoanarchy.org/wiki/Random_hostname_on_boot
    is line one necessary ?
    /sbin/ifconfig wlan0 down
    /sbin/(or wherever)/macchanger -A wlan0
    /sbin/ifconfig wlan0 up
    And that gives you a random MAC ?
    DeadBeefCafe ? HELP!!! ALERT!! A HACKER!!!!
    macchanger -A gives you a random MAC from a KNOWN
manufacturer.
    and macchanger can be easily scripted.
    This second example does not give you a random MAC.
Meanwhile, at the alt.internet.wireless Job Justification Hearings, Shadow
chose the tried and tested strategy of:
Come on, it's not that hard to put information together from this thread:
$ sudo ifconfig wlan0 down hw ether  `echo $RANDOM$RANDOM | md5sum | sed -r
's/(..)/\1:/g; s/^(.).*$/\1/;'`
 <http://ale.cx/ (AIM:troffasky) (UnSoEsNpEaTm@ale.cx)
 18:25:48 up 4 days, 45 min,  7 users,  load average: 0.07, 0.34, 0.22
 Qua illic est accuso, illic est a vindicatum
    Not that hard ? I won't learn that kind of stuff in the time I
have left :)
~$ echo $RANDOM$RANDOM | md5sum | sed -r 's/(..)/\1:/g; s/^(.).*$/\1/;'
e0:02:83:73:7a:2a
    Yeah, it works.
    The macchanger program can give you real manufacturer strings
though. It checks the http://standards.ieee.org/regauth/oui/oui.txt (uses
an older version).
    []'s
Why on earth should this be the case?
Chris
No, you can change it anytime you like, BUT you may lose your gui
desktop access because of name change and you would need to restart
any service/daemons which use the node name.
Examples: mysqld, postfix, sendmail, leafnode, dovecot,..
Nobody understands me correctly.  I don't even understand myself
sometimes.
That might not help as your black hat, mask, and cape, with the skull
and crossbones are rather obvious.  Shave your head and get some
tattoos, and you'll fit right in.  To complete the disguise, I suggest
you camouflage your laptop as a pizza:
<http://www.humanbeans.net/powerpizza/
Before you inflict your MAC address manufacturing machine on the
world, you may find it amusing to see how many times you can change
your MAC address connecting your wireless router before it fails.
Download and run:
<http://www.smallnetbuilder.com/mydownloads/max_session_tool.zip
This tool generates new MAC addresses (and therefore new wireless
connections) until the router can't open any more.  The doc is in the
ZIP file.
<http://www.smallnetbuilder.com/lanwan/lanwan-howto/31103-how-we-test-hardware-routers-revision-3
You may need to set the netmask to /16 (255.255.0.0) in order to get a
decent number on high end wireless routers.
Most cheap /24 wireless routers will choke at 253 IP addresses if
they're not smart enough to discard unused DHCP leases or have limited
RAM.  Better routers, that are smart enough to dump unsused leases,
will usually go to maybe 2046 before the MAC address to port number
table fills.  Some will go to about 16000 connections.
If your script just changes the MAC address when you boot, there will
be no problem.  If you script goes insane and spews random MAC
addresses without end, you're likely to hang the router.
As an added misfeature, some routers (i.e. DD-WRT) save the DHCP
leases in NVRAM.  Reboot the router and it's still messed up because
the leases won't flush until they expire, which can take days.
(There's a check box in DD-WRT to disable this feature).
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
  I know nothing about Linux, but can't you put your code into a
bat file and execute upon every boot?
Probably.
The goal is to put it in the 'startup' directory (/etc/init.d/) somehow.
I did find a good way to 'randomize' the MAC address manually:
`echo $RANDOM$RANDOM | md5sum | sed -r 's/(..)/\1:/g; s/^(.).*$/\1/;'`
And, I did find a way to 'randomize' the hostname based on a random
selection out of the standard Linux dictionary of words at /usr/share/
dict/words
The question now is how to tie all that together so that the random wlan0
mac and the random hostname are assigned upon reboot of the Ubuntu 10.04
laptop.
As an FYI: I took a quick peek through Ubuntu's init.d/ scripts.
I will suggest you change hostname on shutdown since I did not see
when hostname set during boot/start.
Put you code in rnd_hostname script I suggested and create a
Kxxrnd_hostname link in /etc/rcx.d
Suggest taking one of the scripts in init.d, copy to rnd_hostname and
start playing around.
Better yet, install virtualbox, create a guest virtual machine, take a
snapshot and start playing around. That way if you screw it up, you
can delete current snapshot, create a new on, and try again.
Changing hostname on the fly can cause you to lose gui desktop manager.
You might want to http://groups.google.com/groups/search to check out
init scripts.
http://groups.google.com/groups/search?as_q=runtime+script&as_epq=&as_oq=&as_eq=&num=10&scoring=&lr=lang_en&as_sitesearch=&as_qdr=&as_mind=1&as_minm=1&as_miny=2010&as_maxd=1&as_maxm=1&as_maxy=2010&as_ugroup =*ubuntu*&as_usubject=&as_uauthors=&safe=off
alt.computer.security would be off topic now that you have a direction.
comp.unix.shell for scripting questions.
alt.os.linux.ubuntu for specific ubuntu questions.
ubuntu has a forum where you might get some help.
Meanwhile, at the alt.internet.wireless Job Justification Hearings, Bit
Twister chose the tried and tested strategy of:
I've got /etc/init.d/hostname on my 10.04 laptop, although it's an Upstart
skeleton script so I can't actually see what it does.
 09:32:51 up 1 day, 15:52,  3 users,  load average: 0.00, 0.02, 0.04
Yes, saw that, and grep'ed for hostname and never saw it called
from another script in init.d or a rc?.d link.
Found several directories where scripts could be placed to munge things.
Example: /etc/network/if-up.d, if-down.d, if-pre-up.d, if-post-down.d
If it were me, it would be a shutdown script to modify /etc/hostname
and set a fake MAC with "hwaddress ether 01:02:03:04:05:06"  under the
wifi interface in /etc/network/interfaces.
Next system boot would have new values.
Meanwhile, at the alt.internet.wireless Job Justification Hearings, Y Knot
Wouldn't it be funny if you got busted because your laptop had assigned
itself a hostname of 'pederast' [or similar].
 09:39:31 up 1 day, 15:59,  3 users,  load average: 0.04, 0.01, 0.01
Wouldn't it be funny, if the noobs got busted because they don't realize
MAC addresses follow certain conventions and totally random selections
stick out even more than a consistent "standard" MAC address.
Yeah, once again the noobs are getting it all wrong and missing an
already well established solution...
Oh, and wireless connections aren't typically established under Linux
desktop distros until a user logs in, so setting up a fake MAC at boot
time isn't only unnecessary, it could actually defeat the purpose
completely depending on distribution. If an interface is reinitialized at
login it would revert back to it's "natural state".
Site Timeline
