Linksys WUSB54G Downloads Transfers very SLOWWWWW
With a Linksys WUSB54G Downloads Transfers on this USB Unit are much slower than Upload Transfers (an order of magnitude slower ~60 KB/s compared to
+600KB/s)!!! Transfers with a Belkin G Card (PCI) on the same WLAN can easily go over 1MB/s in both directions (AP is a D-Link WBR-1310). Therefore I question whether there might be a Configuration/Compatibility "Problem" between the Linksys and D-Link Units or whether this is just a "Defective" WUSB54G??? Tried several different PCs and both USB 1.1 and 2.0 Ports with Tx/Rx Rates Stable at 54 Mbps, although Downloads remain much slower than Uploads (all Tests were within the LAN/WLAN) Any of you Wifi Buffs able to offer some insight???
Lawrence Houston -- ( snipped-for-privacy@greenfield.dyndns.org)
Lawrence Houston
