Linksys WRT54GS firmware update question
this probably sounds like a dumb question. I just got this router and went to upgrade it to the latest firmware. During the upgrade process, you have a little progress bar in the web-based interface, while the new firmware is loading. I was just wondering why the progress bar doesn't finish all the way before you get the screen that says the firmware has been sucessfully updated. Everything 'seems' to work fine, but I was wondering if maybe the new firmware really didn't completely load. Help would be appreciated--thanks.
TheKeith
Open up a browser window and log into your router.
Under status, what is the firmware version? It should say 3.37.2
-- cnewton at akaMail.com Anti-Spam filter in place--
Curtis Newton
yeah it does--thanks.
TheKeith
