Hello! I got a Linksys WRT54G v.2 802.11G Broadband Router (already upgraded the latest firmware), and 2 Linksys WPC54G PCMCIA NICs v.1 (the lastest driver), 2 Notebooks, one with WINXP Pro and one with WINXP Home ed., they work fine for WEP, but when i switch to WPA-PSK (both AES and TKIP), they can't connect anymore (can't acquire the network address). I am sure it's not the passphase problem, I try to uninstall the driver and install again, it worked fine once on my WINXP Pro, but after rebooted, it failed again.. I try to input the SSID, select WPA-PSK, and then the passphase directly in the wireless tab, it can't help.
I've contacted Linksys and of course they couldn't help me. Do you hv this problem and how can you solve it.. Thank you very much!
Cheers, Kent
