(I didn't see the original message on my news feed, so I'm replying to the reply. Sorry.)
I've lost three of the old 5VDC 3A Linksys power supplies used on the WRT54Gv1 incantation. Every model after that used 12VDC 1A power supplies, which seem to work just fine. The WRT54G has a very wide range switching regulator inside that will run on anything from about
4VDC to perhaps 18VDC. If the power supplies that are blowing up are 5VDC 3A models, I suggest trying the 12VDC 1A flavor.Another possibility for PS failure is overheating. I had one customers that blew up their router wall wart because the floor heater had cooked the power supply sufficiently to blow the internal thermal fuse (usually 175F).
There are also cord flex problems. Molded power connectors often go intermittent. Same with breaking the power connector inside the WRT54G. Check the power supply output with a DC voltsguesser.
Power spikes and AC line glitches sufficient to fuse a power supply would also blow up most of the home electronics in the house. Dropping the neutral might cause one phase of the power line to go overvoltage. It's possible, but there would probably be considerable damage to other things in the house. The typical surge protector will also protect (or destroy itself) against overvoltage.
