For some reason, I can no longer get dhcp to work on the lan/wired side.
It works fine on WLAN/wireless side. I can get an address and PING
192.168.1.1 on the WLAN side just fine. I even tried updating firmware on the WLAN side and it was successful (AFAIK).On the LAN side, even if I use a static IP, I cannot ping 192.168.1.1. I even tried adding an arp entry on the PC for the mac address of the unit. still not work.
However, if I do a continuous ping to 192.168.1.1 from the LAN PC, I will get 4-5 responses when I power reset of the router or do a soft reset for 30 seconds, etc.
Is there some setting to allow the management IP and functions to be bridged to the LAN side?
The only thing I have done lately is tried the latest version of code for my wrt54g (hw) v1.1 - firmware v4.20.7. Also, I haven't been using my Internet port lately since my ISP has been f***** around, I can only keep one PC on the Internet until they get done with their address space migration and other odd changes.
Thanks
