SUMMARY: Internet connection hangs when loading webpages when using Linksys WRT54G v5.0 - works fine when connected directly through Dlink modem.
I'm experiencing intermittent problems with my Internet connection. Sometimes pages fail to load (timeout while still trying to connect to the site), or hang (annoyingly) whilst loading. Sometimes I am unable to access the router's set up page (via 10.1.1.100, the router's IP address), or the set up page hangs while loading.
TESTING ALREADY PERFORMED: The Internet is lightning fast and has no problems when connected directly via my ADSL Modem. When connected via the router, my PC does get an IP address (obtained via the router's DHCP), and all DNS settings appear correct on the router's set up page. Strangely, at the times when I can't access the router's set up page, I can successfully ping the router on the IP I'm trying to connect to! I'm directly connected to the router via CAT 5 cable.
FURTHER SET UP DETAILS: I am using a Dlink DSL-502T to provide the Internet connection (ADSL2+, 18Mbps sync speed). The Dlink modem is in bridge mode, and the Linksys router is in PPPoE mode, and authenticates fine.
I've posted this question here also
Thank you! Roy
