I've just got a LinkSys WRT300N wireless router. I've configured this so the wireless uses WEP and disabled DHCP, because I've got a domain controller that is a DHCP server. This seems to work. But after about a half hour the connection became sluggish. Trying to ping my server resulted in 50% loss and a avg ping time of more then 1000ms. Browing became very slow and trying to access network shares became almost impossible.
Reviewing the configuration of the Wireless I could not find anything that might cause this to happen. But when I disabled the wireless on my laptop and used a cable the ping was normal. The only settings I changed for the Wireless are the SSID and enabled WEP, the other settings are default.
Although it seems to work correctly now, I'm very curious what caused the hickup. Any information is welcome, because if it happened once; it is bound to happen again and I want to be prepared the next time.
Greetinx,
Jos.
