Hmmm - I have seen conflicting reports about whether this is do-able, but has anyone in the UK successfully extended a WAG54G's range using the newish WRE54G Range-Extender unit please?
Also - I have seen some peeps advise (if it can be done) to use identical SSID to enable seamless 'hand-off' roaming between units (ie. at either end of a property), whereas others advise to use similar but *distinct* SSIDs to allow one to 'force' client to connect to either unit...yea/nay?
TIA, Aitch
