Are you able to use the client configuration utility that came with your wmp54gs wireless adapter? the steps to be followed would be: a) power up the Linksys router b) associate with the router using the utility ( by using the site survey link and then connect) that came with the card and not with WinXP wireless c) read the manual of the router to see what its default IP address (on the LAN side) is. d) manually set an address in the same address range ( eg if router default is 192.168.0.1 then you can set your card's address as
192.168.0.100) e) fire up your favorite browser (once your network is up, after association) and then in the address box type in http://192.168.0.1 ( or whichever is the router's address) and then configure the router to suit your needs. All this is possible only if you get past step b) all the bes!!!- Vote on answer
- posted
19 years ago
