Hello,
There are 2 computers with this card. Both of them have mentioned OSes. I noticed that one of them blinks the green diode in card panel as soon as card is up (whenewer there is a signal or not, so I guess it is a correct behavior of this card).
In the other computer card stopped blinking diode and it has problems with getting network connection (it used to work fine).
Should I remove card and install it again, or is it a permanent hardware failure ?
robert
