I have two Win2K computers using Linksys WUSB54 wireless access points on my wireless network. Both computers have the updated WLAN Monitor program v. 2.0 running (which basically corrected the memory leak problem I was having.)
I now have noticed two problems with this program which are causing me a bit of a headache.
1). I can not delete the DEFAULT Profile in the program. This would not normally be a problem, but the DEFAULT program doesn't contain the correct information for my wireless connection, so I operate on a 2nd profile. Everytime I reboot the computer, I have to manually re-connect to my second profile.2) I realize I could just EDIT the DEFAULT Profile to contain my required information, but that doesn't work. Soon as I get midway through the EDIT process, the WLAN progarm just closes suddenly and restarts itself, without holding the information I was trying to enter, nor allowing me to finish the entry process.
Anyone heard of these issues? I did a fairly quick check on LinksysInfo.org forums but didn't find any subject containing these questions.
Ed
