Is there any internal / performance difference between U.S. LINKSYS WKPC54G (or similiar models) and the U.K. version? Meaning, will they be compatible over the same network?
If they are compatible, what would be the best single power converter to use, to run a playstation2 AND a wireless gaming adapter simultaneously? Im a bit confused on the VA capacity rating(S). I understand both the console and the adapter run at 120v. The 120-240 us/uk products are easy to find, but which one will support both hardware without frying?
