I have a problem with the above and my one PC with a WUSB54G adaptor. It used to work, but has stopped working recently for no apparent reason.
I have upgraded the router firmware to IIRC v3.03, and can SEE the network, which says that the connection is good, but IE6 refuses to access websites. Access is possible via my Ethernet Card connected to my cable set-top box.
I use ZA Pro, and have made sure that I have added the DHCP and DNS server addresses to the trusted zone (and also tried the internet zone) to no avail. I have tried switching off ZA Pro to no avail.
I can access the router set-up via the wireless adaptor, have tried cloning the MAC address, tried switching off WPA security, both to no avail.
Does the fact that I cannot access any websites even by connecting the Ethernet cable to the router and the router to the set-top box imply that the problem is with the router ?
Any help would be much appreciated as I'm completely lost now and am not especially au fait with wireless routing anyway, so am generally just trying things I find in this group.
TIA
