I had configured a linksys wireless router/access point about a month ago. The client was having some connectivity problems.
When I looked at it, it appears it was set back to the factory defaults. (ie paperclip reset).
Neither of the owners recall doing anything with the router. They do have a couple of young kids. .
Anyway, I haven't seen a spontaneous reset. I was wondering if anyone has seen this happen before where you can verify that the router reset to the factory defaults without someone doing it accidentally or intentionally.
I'm guessing that the configuration is stored in flash memory that would not be dependant on an internal battery. Does anyone know if the config info is dependant on an internal battery in the linksys routers?
Thanks
chris
