Linksys WGA54g
Hello gentle people,
I'm trying to install this thinggy for about 5 months. Firmware updates. etc etc etc....
The reseller gave advice and i bought his blabber.. :(
Unfortunatly it just doesn't work
What I wanted was
Internet WifiRouter LAN WGA54g Showcenter
And guess the freakin' thing just doesn't come online....
With a laptop via that thing online no problems... Than i'll shut it down. And replugg it somewhere else into the wall and nothing happens anymore...
Anybody a idea?
thx in advance...
LeoFric
LeoFric
Maybe my first posting was kind of uncomplete...
I'm lookin to resolve a problem to bind two wired networks together. With the WGA54g adapter from linksys this should be possible.
However.... up until now unsuccesfull.
When I install it and connect the wiredLAN behind the game adapter nothing happens...
With just one laptop behind the adapter at least I can ping my own network at the other end of the wifi bit.
So somewhere it does work just not when I connect the Pinn. ShowCenter.
Any pointing towards a possibele solution is appriciated.
I'm just stuck with it.
Greetz,
LeoFric
LeoFric
Ow well and as no one eve bothers to ask I just go wondering off again.
Actually I solved the problem on my own..
ThX great group...
LeoFric
