In article , Ash wrote: :I'm about to put a wireless network into my three story townhouse and :will be using the following setup
:After some research I have narrowed down the selection to two choices :- either a linksys WET11/BEFW11S4 combo or a dlink DWL-810+/DI-614+ :combo. I'm having trouble choosing between them. Feature sets and :price are pretty much the same. So I thought I'd draw on all the :experience here and ask which do the group prefer and why?
I have WET11/BEFS11S4 (almost exactly what you propose.) I choose the WET11 over the 614+ after looking at the archived postings for this group and seeing what people's experiences were. What I gathered was that if you have a 614+ and it works, then it is solid, but a non-trivial fraction of the time you can't get the device to work no matter what you do. On the other side, I found that very very few people had reported problems getting a WET11 to work.
As I recall, I also found an important technical detail. My memory is fuzzy now, so you should cross-check this, but I seem to recall finding out that the 614+ would only work with D-Link equipment; the WET11 was creditted to work with a number of different manufacturers.
